I had a really hard time finding how I could display in the summary the group_duration for each group.
By default the group_duration metric is aggregating the duration of all the groups (which I find quite counter intuitive).
The only way I’ve found to be able to see the group_duration for each individual group is to define thresholds.
For example if I have a group named ‘get-profiles’ and a group named ‘get-profiles2’, without defining thresholds here is the output :
group_duration.................: avg=112.17ms min=59.03ms med=120.24ms max=157.25ms p(90)=149.85ms p(95)=153.55ms
Now to be able to see the group_duration for each group I had to set these thresholds :
export const options = {
thresholds: {
'group_duration{group:::get-profiles}': ['max < 1000'],
'group_duration{group:::get-profiles2}': ['max < 1000'],
Which gives me the desired output :
✓ { group:::get-profiles2 }....: avg=59.03ms min=59.03ms med=59.03ms max=59.03ms p(90)=59.03ms p(95)=59.03ms
✓ { group:::get-profiles }.....: avg=120.24ms min=120.24ms med=120.24ms max=120.24ms p(90)=120.24ms p(95)=120.24ms
Is there any better way to output the group_duration for each group ?
I find it weird that I have to create thresholds (which I don’t care about here) just to be able to see them.
Same question of http_req_duration. How can I display the duration for each tag without having to create thresholds ?
Ex:
thresholds: {
'http_req_duration{id:user-token}': ['max < 1000'],
'http_req_duration{id:profiles}': ['max < 1000'],
is the only way I’ve found to have this ouptut :
http_req_duration..............: avg=79.1ms min=44.22ms med=73.34ms max=119.75ms p(90)=110.47ms p(95)=115.11ms
{ expected_response:true }...: avg=79.1ms min=44.22ms med=73.34ms max=119.75ms p(90)=110.47ms p(95)=115.11ms
✓ { id:profiles }..............: avg=58.78ms min=44.22ms med=58.78ms max=73.34ms p(90)=70.43ms p(95)=71.89ms
✓ { id:user-token }............: avg=119.75ms min=119.75ms med=119.75ms max=119.75ms p(90)=119.75ms p(95)=119.75ms
