Add decimal points
I’m using grafana v8.5.4 and influx2, I have a snmp setting so I getting integer temperature.
143 °C but should be 14.3 °C, I’m not sure how to add the decimal point in the last number.
any function that could be help?
this is the csv data.
“Time”,“temp.TempR1”
2022-06-07 13:46:00,152 °C
2022-06-07 13:47:00,152 °C
2022-06-07 13:48:00,152 °C
2022-06-07 13:49:00,153 °C
2022-06-07 13:50:00,153 °C
2022-06-07 13:51:00,152 °C
2022-06-07 13:52:00,153 °C
2022-06-07 13:53:00,152 °C
2022-06-07 13:54:00,152 °C
2022-06-07 13:55:00,152 °C
2022-06-07 13:56:00,153 °C
2022-06-07 13:57:00,152 °C
2022-06-07 13:58:00,152 °C
Best would be correct data in the csv, but that’s not the answer you want to hear. :smiley:
You can use a Transformation to devide your value by 10:
  1. Create a new “Add field from calculation” Transformation
  2. Select Binary Operation
  3. Choose the field that should be devided by 10
  4. Give it a new Alias if needed
  5. Activate switch and you only see the new calculated Value
Wow! good job.
that’s I wanted heard
