Hi
In the past I have made a grafana install with docker using the following procedure:
Docker version 2.3.0.3 (45519) MAC OSX v10.15.5 (Catalina)
Run Grafana container with persistent storage (recommended)
# create a persistent volume for your data in /var/lib/grafana (database and plugins) docker volume create grafana-storage # start grafana docker run -d -p 3000:3000 --name=grafana -v grafana-storage:/var/lib/grafana grafana/grafana
I am using a MAC OS X Catalina on both computers.
In order to backup the grafana instance I used the command below:
docker container export grafana-lab > grafana-lab.tar
and
docker container export --output grafana-lab-bkp <containerid>
To restore the container in the new computer I used the command below:
❯ docker import grafana-lab-bkp grafana-lab
output:
sha256:b64b8a9984ad24b789afea30a72535e1d447c06df9(...)
❯ docker image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
grafana-lab latest b64b8a9984ad About a minute ago 237MB
My questions are:
- How should I proceed in order to be able to restore a container with its volume as I created using the “recommended” approach?
- Is there a viable alternative like with grafana-cli can I generate / export a json file with all its contents and import it on another grafana?
Thanks.
