- What Grafana version and what operating system are you using?
“version”: “9.3.0-beta.1” -
Using Canvas plugin with a metric that sometime is not available, display : “Double click to set field”
Try using Standard option → No value not work.
Using: Standard option → No value not work to get NA value when the metric not exists -
What happened?
I see : “Double click to set field” instead of NA -
To get NA on the value of the not existed metric. -
I use override on the metric that not available all the time with standard option No value -
No errors -
Did you follow any online instructions? If so, what is the URL?
I didn’t find accurate data in the confluence except for :
Canvas | Grafana documentation
