Chained variables in case of using Azure Data Explorer (ADX) as Data source
    Grafana 8.5.2 on a Windows Server 2019.
    My database is Azure Data Explorer (ADX). So, I am using the KQL query language.
    I have defined some Chained variables and they are all good. However, the query fails when I switch any of the variables from the single selection mode to the Multi-value mode.
    In addition, when I change a top-level variable, the dependant variables to that don’t work either.
    This is the query of the Dashboard.
    (Scada_t002 | project ValueAsReal , Metadata_Units ,RecordTime , Meta1=Metadata_FullNameDelimited_1 , Meta2=Metadata_FullNameDelimited_2 , Meta3=Metadata_FullNameDelimited_3
    | where $__timeFilter(RecordTime)
    | where Meta1 == case(‘$Meta1’==‘None’,‘’,‘$Meta1’)
    | where Meta2 == case(‘$Meta2’==‘None’,‘’,‘$Meta2’)
    //| where Meta3 == case(‘$Meta3’==‘None’,‘’,‘$Meta3’)
    |where Metadata_Units == case(‘$Unit’==‘None’,‘’,‘$Unit’)
    | order by RecordTime asc)
This is the query for the top-level variable
(Scada_t002
| extend SystemName = case(isempty(SystemName)==true, ‘None’, SystemName)
| summarize by SystemName)
and this one is the dependent variable.
(Scada_t002
| where SystemName ==‘$SystemName’
| extend Metadata_FullNameDelimited_1 = case(isempty(Metadata_FullNameDelimited_1 )==true, ‘None’, Metadata_FullNameDelimited_1 )
| summarize by Metadata_FullNameDelimited_1 )
  • What happened?
    The query returns nothing. Moreover, the dependant (subsequent) variables return nothing as well.
    I expected that the query would understand multiple values in a Parameter (variable).
I also tried to use (in~) instead of (==), but it didn’t work either.
No data is retrieved for the main query and the queries in the subsequent variables.
I tried to change the query from (==) to (in~) but it didn’t help out.
