Hi, is it possible to change a scenario’s duration from the command line?
Yes, using k6 environment variables you can inject values in the exported options
from the cli, including in scenarios
: Environment variables
See Is it possible to pass vus value in k6 CLI using constant-vus executor in config.js? for an example
