Configuring SSL/TLS settings with Grafana
We are using Grafana to monitor an old legacy application which doesn’t hook well into our standard monitoring tools.
A recent Security scan reveals that weak ciphers and TLS1.0 is enabled. We want to disable that however I cannot find much information. We are hosting on ubuntu, on linux it appears it need to be configured on application level. I cannot work out what is running underneath grafana.
Any guidance would be much appreciated.
Upgrade your Grafana or hide it behind reverse proxy (nginx, apache, …), where you can configure TLS.
https://localhost:3000/t/grafana-linux-server-vulnerability-medium-cipher/8041/2
