We have data inside cloudwatch (api gateway call count )which we would like to visualize in a heatmap like the picture below.
We have selected the Heatmap Visualization, however we are not able to get the data correct. On the Y axis, we would like to have the weekdays, and on the X-axis we would like to have the hour (24 hour). Than the color should indicate what the amount of traffic was which was used.
I only get the result where the Y axis indicates the amount of calls, but not the days …
Do we have to add expressions to enable this, or how can we achieve this graphic?
Thanks in advance!
Kind regards
Rob
