Creating lines between points in geomap
Is it possible to draw lines between markers/points on the geomap panel in grafana?
I have a panel in grafana with a set of static and dynamic markers/points holding values , i would like to visually connect the markers/points holding the same value. Would this be possible in the geomap panel?
/Max
No. I would say heatmap feature of geomap is there to visually connect points with the same values.
Alright, thanks for the reply
