Custom Plugin Installation issue
Hi ,
I’m facing an issue over grafana dashboard while importing one of them pmm dashboard and getting error as Panel plugin not found for pmm-update-panel .
I have dir of custom plugins but unable to install this plugin via grafana cli command . Any input would be greatly appreciated .
pmm-update-panel :
| |-- pmm-update-panel
| | |-- index.html
| | |-- modal.html
| | |-- module.ts
| | |-- plugin.json
| | -- style.css | – README.md
Are you trying to install this set of dashboards for Percona: https://github.com/percona/grafana-dashboards ? The pmm-update-panel seems to be part of that repo but is not published as a plugin to https://grafana.com/grafana/plugins - and this is why you can’t install it with the CLI.
Or is it the percona app: https://grafana.com/grafana/plugins/percona-percona-app
Anyway, you can check the Grafana server logs for errors on why it failed to load.
