Elements on Canvas not resizing properly
    Grafana v9.3.6 ; Raspbian
    The ability to merge elements with photo so you can resize both at the same time
  • What happened?
    When i place elements on photo in canvas, when i try to resize the panel in dashboard all text fields stay in same place while photo gets smaller… It doesnt display correctly on mobile device
    I want to have a photo of a house with corresponding measurements in specific places so i can freely resize photo and i can view it from my mobile device/computers etc.
photo1: elements in the right places on photo
photo2: missplaced elements
photo3: normal panel look
photo4: resized panel look
photo5:
view from mobile device
Hi @skvarcmatevz,
Thanks for opening this post.
Can you please try to reproduce this same issue (with minimum steps as possible) on https://play.grafana.org/ and then share the dashboard link so that we can view it?
