Failure importing a dashboard
I am getting the following error when importing certain dashboards:
“Failed create dashboard model. e is undefined”
The dashboard I am trying to get working is: 10829 (https://grafana.com/grafana/dashboards/10829)
Grafana v 6.2.5 (RHEL7 ppc64le)
grafana-clock-panel @ 1.0.3
grafana-piechart-panel @ 1.4.0
That dashboard was created with Grafana 6.6.2 (you can see it in the dependencies section) and your is only 6.2.5. Solution: try to upgrade your Grafana.
I’ll do an upgrade now.
That did the trick. I upgraded to Grafana 6.7.2 and successfully imported this Dashboard. Thank you!
