Forecast: Display future values in Grafana, e.B. for the next 20 hours
Every 30 minutes, https://api.awattar.at/v1/marketdata’s stock market prices are updated with a JS for the next 24 hours. The values are also displayed in the iobroker under JS. Unfortunately, I can’t see the values in Grafana in the graph. What parameters do you have to set to display them. I have already extended the period to the next 24 hrs. Thank you in advance for helping to solve the problem.
You can check the following solution :
https://localhost:3000/t/future-time-shift-to-support-forecast-data/4165/5
There is also a new feature on 7.4 for live streaming you should totally check out :
https://play.grafana.org/d/nP8rcffGk/1-new-features-in-v7-4?orgId=1
Hope it helps.
Good Luck
