Getting following error while running script on k6
WARN[0002] Request Failed                                error="Get \"https://test.k6.io\": http: server gave HTTP
response to HTTPS client"
import http from 'k6/http';
import { sleep } from 'k6';
export default function () {
  http.request('GET','https://test.k6.io');
  sleep(1);
Hi @kalyanipawar
I was testing the same script as you and I do not get this error.
Can you tell us more about your platform? Do your requests go through a proxy? Are you running k6 with Docker? Do you get the same error with http.get('https://test.k6.io');?
If you can share the command you use and a bit more details about your environment, we might be able to help you troubleshoot.
Cheers!
