Going to production, Grafana configuration best practices?
I have searched the Grafana community and docs and have not yet found anything regarding putting Grafana into a production environment. Are there any resources that detail best practices for setting configuration for grafana for a production environment?
What types of things should we prepare for? Some of the things I’ve thought of are:
  • Go to HTTPS
  • Lockdown administration accounts
  • Put up a reverse proxy in front of Grafana for port forwarding
  • Turn logging to a production level logging setting
  • Setup high availability (which doesn’t work with alerting?)
Thanks for your thoughts, in advance.
-Brant
Backups / restore procedure.
Dear @jangaraj,
We found a tool which might be helpful in this context.
https://localhost:3000/t/backing-up-or-committing-dashboards-to-github/26194/2
With kind regards,
Andreas.
