I just want to make sure here that I understood you correctly:
So I cannot run Loki with HTTPS, even if it’s done using a proxy but instead, I should just use HTTP and basic auth?
Or can I use Loki with HTTPS if I do so via a proxy?
The blog post you linked only talks about the former but I thought I could enable SSL through a proxy.
