Hey folks - I have an event driven API, where the API returns immediately with a token, and then the user polls a status API to see whether the task is complete. A different debugging API returns the total available results at a given time. For example:
Call 1: 201 results
Call 2: 201 results
Call 3: 206 results
Call 4: 218 results
I’d like to see the same stats that the Trend metric creates, but on the Deltas - [0, 0, 5, 218]. Knowing that the VUs can’t guarantee order, it would be completely fine to save the [itr #, total #] and on teardown sort the iterations and batch add the trend metrics (which would work in a distributed world). That said, when I create a local map/array to collect all the results for the teardown, they are only accessible during the iterations, but not the teardown phase.
How would I go about getting this time of metric set up? Thanks!
