I am attempting to configure Pomtail to send historical logs to Loki. The logs are in JSON format, but I can also get them in CSV or XML. I can change pretty much anything I need to about the logs. This is a code coverage report, so it’s just key-value pairs including a timestamp of when the report was run.
I’ve tried supplying the timestamp in both UNIX and RFC3339 formats. For the UNIX timestamp I supplied it as both a string and an integer. I’ve attempted to use the following formats:
unix
“unix”
Unix
“Unix”
1562708916
“1562708916”
I thought maybe there was some problem parsing Unix timestamps so I switched to RFC3339 format but I’m still not getting anywhere.
At first I thought that I was having problems because the timestamp was being loaded under “detected fields” instead of “log labels” in the Grafana interface, but after messing with it for several hours, I finally got timestamp to show up under “log labels” by adding the - labels pipeline stage configuration, but the timestamp configuration still does not seem to do anything.
Googling this problem yields a lot of different weird edge cases including using double quoted strings for some fields. Is there any example of a working implementation of using a timestamp from a JSON payload instead of using the timestamp that Grafana automatically attaches to the log?
I have the exact same issue, I have some logs with their own timestamp. I’ve managed to extract them as timestamp labels, but grafana still always shows the time as the time I got the logs, so that huge file as one timestamp. I still haven’t figured out how to use those timestamp labels to get a timeseries of the logs. Did you manage to figure this out? Or can anyone help?
Why is it so hard to swap out Loki’s automatic timestamps for log timestamps?
I finally got it working! Thanks to everyone in this thread, you got me to the one yard line.
In our case, the date format was a little off. I had to figure out the Go date formats - and it’s quite literal, the mythical ‘2006-01-02 15:04:05 -0700’
pipeline_stages:
- multiline:
firstline: '^\[\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2}\s[+-]\d{4}\]\s'
max_lines: 512
max_wait_time: 3s
- regex:
expression: '\[(?P<time>\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2}\s[+-]\d{4})\]\s\[(?P<procid>\d*)\]\s\[(?P<severity>.*)\]'
- labels:
# these have to be parsed from the regex, otehrwise list
# static labels in 'labels' above
time:
severity:
procid:
- timestamp:
# [2020-08-21 18:37:05 +0000] [3366] [INFO] Booting worker with pid: 3366
source: time
# this is a weird Go format. See:
# https://grafana.com/docs/loki/latest/clients/promtail/stages/timestamp/
format: '2006-01-02 15:04:05 -0700'
This allowed us to import some historical logs. I found several articles that said historical logs can’t be parsed, but for me the solution was:
Startup Promtail
Shutdown Promtail
Edit the ‘positions’ file
Change any offsets for logs you want historical information on to “0” and save.
