How to add icons to radio buttons with a relative URL?
In module.ts, I can add radio buttons this way, and add image urls to show a little icon instead of having it show only text. This works great with absolute urls but I created my own icons to display instead. I want to use a relative url instead using my custom icons.
    .addRadio({
      settings: {
        options: [
            value: 'v',
            imgUrl: 'https://link-to-image.svg', // << change to './img/custom.svg'
I have placed them in an ./img folder which contains the panel logo, but when I build the plugin and open Grafana, I don’t see my images in the resources tab in the inspector (and I don’t see the icons in the radio buttons.) I am assuming the images are not packaged when I build the plugin. How do I fix this? Thanks!
You can import the images, but you need to add the type definitions.
Create a types folder
Create a file called types.d.ts
Add the below code into types.d.ts
declare module '*.svg' {
  const value: any;
  export default value;
declare module '*.png' {
  const value: any;
Add types to the include in tsconfig.json
Inside module.ts
import logo from './img/logo.svg';
import buildingOverview from './img/screenshot-building-overview.png';
    .addRadio({
      path: 'test',
      settings: {
        options: [
            value: 'v',
            imgUrl: logo,
            value: 'v',
            imgUrl: buildingOverview,
Works perfectly! I didn’t know that I needed to add the type definitions. Thank you! :smile:
