Grafana v6.0.1 (0c44a04)
Hello people!
Im currently trying to figure out how I can combine two queries into one. I have currently done something like this:
I have created a variable called $args and that has a value called prometheus_port
which returns e.g. localhost:8006
- With that value I want to use localhost:8006 inside the instance (process_resident_memory_bytes{job="node", instance="USE prometheus_port value in here"} )
without needing to manually enter in that.
Is that possible to do?
So basically that would be the same as doing
process_resident_memory_bytes{job=“node”, instance=“prometheus_port from scraper_script_name_total{store=”$args"}"}
Is that possible with Grafana?
