Using cloud version 8+
I am trying to query AWS TimeStream data between the start and end time of a dashboard time range. No matter what I try I get bad query error.
I can go and query the table directly at AWS by using the format below. I get good data:
SELECT * FROM “MyDtatbase”.“MyTable”
WHERE time > ‘2022-05-25 00:00:00’
I have found that you can get the start time and end time of the dashboard by using these functions:
${__from} and ${__to}
How does one convert milliseconds from epoch to the correct date format for AWS?
2022-05-25 00:00:00
