Hi, I’m totally lost on how to display data in x.x% format. Here is what I have
Given these data, total of 3072 and failure of 13. I want to calculate them by ((13 * 100) / 3072) so that it give me 0.42% to be shown in panel.
Using aspercent(A) give me weird value, also the same with doing binary operation in transformation. Nothing works for me.
Please advice.
Welcome
Please provide
1.version of grafana
2. Data source
3. Sample data as inline csv
Timeline,metric,value
2022-05-13 02:23:33,'heat',23.5
Add an expression that references the queries. Not sure what white flacon is (please add reference here to see if it is something we can download) but generally one can do one simple query to get all of this in one take
You can also use a calculation, and tick the radio button that says Replace all fields:
That will leave you with only one value displayed.
