So under the documentation there is an example on how to add a drop down menu to PanelPlugin
import { ShapePanel } from './ShapePanel';
interface ShapePanelOptions {}
export const plugin = new PanelPlugin<ShapePanelOptions>(ShapePanel)
.setPanelOptions(builder => {
builder
.addSelect({
description: 'Select shape to render'
settings: {
options: [
{value: 'circle', label: 'Circle' },
{value: 'square', label: 'Square },
{value: 'triangle', label: 'Triangle }
I would like to know how do I make it so that a certain function fires with the correct value when we select a label from a drop down menu.
