Hello, I want to apply loki for several log data sources. For example,
the first Netflow data source ( short for: netflow1), it needs loki write (1 pod)+ loki query (30 pods)+loki frontend (2 pod)
the second Netflow data source( short for: netflow2), it needs loki write (1 pod)+ loki query (30 pods)+loki frontend (2 pod)
the third Netflow data source( short for: netflow3), it needs loki write (1 pod)+ loki query (30 pods)+loki frontend (2 pod)
the first DNS data source ( short for: dns1), it needs loki write (1 pod)+ loki query (20 pods)+loki frontend (2 pod)
the second DNS data source( short for: dns2), it needs loki write (1 pod)+ loki query (20 pods)+loki frontend (2 pod)
the third DNS data source( short for: dns3), it needs loki write (1 pod)+ loki query (20 pods)+loki frontend (2 pod)
and so on.
If I set up the whole process for each data source seperately, there will be about (1+30+2)*3+(1+20+2)*3=168 pods. That means a lot of resources (such as CPU ,Memory) are wasted for idle time when there is no query.
Is there any way to share the resources ?For example, there is 1 pod of loki write for each data source ,but they use the same 40 pods of loki query +4 loki frontend for all of them.
that means only need 6+40+4=50 pods for all data sources.
Is there any methods to solve this problem? Thanks very much.
Best wishes.
