How to set dynamically Max and Threshold value?
Hi!
I would like to set the field Max from the section Standard options and the field Thresholds from the section Thresholds from a request. The issue is that I can do it for only one of them but not both.
Here is what I’ve done:
I have 3 queries, the first one is what I want to display in my gauge, the second is the request for the Max value and the last one is the request for the Threshold value (I know I can use percentage but the calculation will be more complexe than * 0.8, it’s just an example).
The problem is when I add a “Config from query results” panel the “Config query” drop down menu shows me “No options found”, yet I have a C query.
Is it because this feature is in Beta or do I understand something wrong?
Thank you for you help :slight_smile:
I sure hope someone has an answer to this - I’m facing the same exact issue.
