With a very simple config
scrape_configs:
- job_name: int3
static_configs:
- targets:
- localhost
labels:
job: int3
__path__: /usr/local/stack/db/logs/*.log
pipeline_stages:
- regex:
expression: "BEGIN failed"
- labels:
level: error
and simple logs
Can't locate nonexistent.pm in @INC (you may need to install the nonexistent module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/x86_64-linux-gnu/perl5/5.28 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /home/tarkhil/GIT/test line 3.
BEGIN failed--compilation aborted at /home/tarkhil/GIT/test line 3.
tail -2 /usr/local/stack/db/logs/test.log | promtail --stdin --dry-run --inspect -config.file /etc/promtail/pipeline.yaml
shows me
Clients configured:
url: http://127.0.0.1:3100/loki/api/v1/push
batchwait: 1s
batchsize: 1048576
follow_redirects: false
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
stream_lag_labels: filename
[inspect: regex stage]: none
[inspect: labels stage]: none
2022-07-17T13:06:32.878357+0300{__path__="/usr/local/stack/db/logs/*.log", job="int3"}Can't locate nonexistent.pm in @INC (you may need to install the nonexistent module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/x86_64-linux-gnu/perl5/5.28 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /home/tarkhil/GIT/test line 3.
2022-07-17T13:06:32.878358242+0300 {__path__="/usr/local/stack/db/logs/*.log", job="int3"}BEGIN failed--compilation aborted at /home/tarkhil/GIT/test line 3.
level=info ts=2022-07-17T10:06:32.879467249Z caller=server.go:260 http=[::]:9080 grpc=[::]:35423 msg="server listening on addresses"
level=info ts=2022-07-17T10:06:32.879627515Z caller=main.go:119 msg="Starting Promtail" version="(version=2.4.2, branch=HEAD, revision=525040a32)"
Why none? How do I do the simple task of marking some log lines as critical errors?
