I am creating a dashboard using grafana and zabbix. Use imageit as the current panel. The problem is that the sensor created in the imageit panel cannot be moved. If you click Create sensor, it is difficult to move the sensor, so it is difficult to place the sensor. Is there a solution?
Related topics
Topic | Replies | Views | Activity | |
Grafana Grid View Panel
1 | 2284 | October 4, 2019 | |
IMG Panel Plugin | 0 | 349 | April 3, 2019 | |
Enhancement request - panel duplicate and panel move function
10 | 10326 | February 14, 2022 | |
Move Library Panels from General to another folder | 3 | 426 | March 23, 2023 | |
Windows snap to a location when dragging | 0 | 235 | October 8, 2020 |
