Configuring ldap in kubernetes grafana but rather than picking specified host, grafana is picking default host.
values.yaml
grafana.ini:
auth.ldap:
enabled: true
allow_sign_up: true
config_file: /etc/grafana/ldap.toml
ldap:
enabled: true
# `config` is the content of `ldap.toml` that will be stored in the created secret
# config: ""
config: |-
verbose_logging = true
[[servers]]
host = "10.10.10.10"
port = 389
use_ssl = false
start_tls = false
ssl_skip_verify = false
# Search user bind dn
bind_dn = "cn=admin,dc=grafana,dc=org"
# Search user bind password
bind_password = 'password'
# Search filter, for example "(cn=%s)" or "(sAMAccountName=%s)"
search_filter = "(cn=%s)"
# An array of base dns to search through
search_base_dns = ["dc=xxxx,dc=xxx,dc=xxx"]
# Specify names of the ldap attributes your ldap uses
[servers.attributes]
name = "givenName"
surname = "sn"
username = "cn"
member_of = "memberOf"
email = "email"
# Map ldap groups to grafana org roles
[[servers.group_mappings]]
group_dn = "CN=abc,OU=xxx,DC=xxx,DC=xxx,DC=xxx"
org_role = "Admin"
# The Grafana organization database id, optional, if left out the default org (id 1) will be used
# org_id = 1
