Is there a way to locate an element within an iframe?
I have used page.frame({ url: ‘mysourceurl’ }); within my xk6 test, but Powershell prints out
“Page.frame(frameSelector) has not been implemented yet”
Hey @jbx,
Unfortunately, we don’t support that feature (yet) However, you can do something like the following:
import launcher from "k6/x/browser";
export default function () {
const browser = launcher.launch('chromium', { headless: false })
const page = browser.newContext().newPage();
page.setContent(`
<iframe></iframe>
<span>outside</span>
page.evaluate(() => {
document.querySelector('iframe').contentDocument.write("<span>inside</span>")
console.log(page.evaluate(() => {
return document.querySelector('iframe').contentWindow.document.getElementsByTagName('span')[0].innerText
page.close();
browser.close();
When you execute the script using xk6-browser, it should return inside
. Please let me know if it helps you.
Awesome! this workaround works fine! glad to bump this!
Hi @inanc,
I’ve been trying your solution lately but got this error:
evaluating JS: DOMException: Blocked a frame with origin from accessing a cross-origin frame.
How can I resolve this solution?
Hi @minhhd,
Welcome to the forum.
Could you share your test script? It looks like the website under test is trying to access an iframe
from a different origin, and it might be best to resolve that issue.
We do provide a workaround which should work if you add bypassCSP: true
when creating a newContext
const context = browser.newContext({
bypassCSP: true
Cheers,
Ankur
