Loki not working in grafana 7.0
Hi Team,
Grafana 7.0 Visualization and overall good. But Loki is not working. Loki shows 404 and I forced to downgrade the version to 6.7.3
Thanks,
Anish
Hi! Where do you get the 404? When configuring the data source?
After upgrade from 6.7.3 to 7.0.1 its not working and showing 404 in data-source. Then I forced to downgrade the version and everything working as expected.
I’d suggest that you try upgrading to 7.0.3, and if you’re still experiencing the issue, please submit a bug report, preferably with a screenshot.
on 7.0.3 also Loki not working getting the same error. I again downgraded to 6.7.3
Still the 7.0.5 version also loki not working
