Hi all,
I would like to know if is possible move library panel from a folder to another… 'cause all them are related to the fist one that I chosen
Thanks, ALEN
what do you mean by library panel?
are you talking about dashboards? or plugins?
moving dashboards manually (it can be done via grafana api)
moving plugins folder, change in config
#################################### Paths ###############################
[paths]
# Path to where grafana can store temp files, sessions, and the sqlite3 db (if that is used)
data = data
# Temporary files in `data` directory older than given duration will be removed
temp_data_lifetime = 24h
# Directory where grafana can store logs
logs = data/log
# Directory where grafana will automatically scan and look for plugins
plugins = data/plugins
I fixed this by interacting directly in the SQLlite DB with a GUI editor. But in the latest versions of Grafana it is also possible to edit the JSON, so there are 2 ways to move libraries dedicated to a page to other folders dedicated exclusively to them.
ALEN
