MQTT Data in Grafana using InfluxDB
Hi there,
currently I am working on an IoT Project for my smart home and I am having some problems.
My Setup looks like following:
DHT22 - ESP32 - MQTT - Raspberry PI 4B - NodeRED - Influx DB - Grafana
Everything works except for Grafana.
I think the problem is, that my measurements are transmitted in a string. I have already read several online articles and I tried to use Docker for example, but nothing helped me and I couldnt find a complete tutorial.
The MQTT publish works, I can display my measurements in the terminal, in NodeRED and in Influx if I use “select * from temperature limit 5” for example.
But Grafana alwas shows:
“InfluxDB Error: unsupported mean iterator type: *query.stringInterruptIterator”
when I try to import the data.
I added a screenshot of the working status at the moment.
Please help me on how to get my Data into Grafana and plotting it in 2 different graphs.
Thank you very much!
Greetings from Germany
Leo
2022-03-10-180146_1920x1080_scrot
