Multi-org plugin provisioning (synthetic monitoring on oss)
    grafana oss in kubernetes - 8.5.13
    Provision plugin configurations for all orgs
    Created configmap with plugin configurations (for synthetic monitoring
  • What happened?
    Plugin settings get provisioned only for org 1 (default org)
    For provisioning to apply to all orgs
apiVersion: 1
apps:
- type: grafana-synthetic-monitoring-app
  orgId: 1
  disabled: false
  jsonData:
    apiHost: <host_url>
    stackId: <stack>
    logs:
      grafanaName: <ds_name>
      hostedId: <ds_id>
    metrics:
      hostedId: <ds_id>
  secureJsonData:
    publisherToken: <token>
  orgId: 2
  disabled: false
  jsonData:
    apiHost: <host_url>
    stackId: <stack>
    logs:
      hostedId: <ds_id>
    metrics:
      hostedId: <ds_id>
  secureJsonData:
  secureJsonData:
  orgId: 3
  disabled: false
  jsonData:
    apiHost: <host_url>
    stackId: <stack>
    logs:
      hostedId: <ds_id>
    metrics:
      hostedId: <ds_id>
  secureJsonData:
ETC
    No errors, no issues. Plugin provisioning works perfectly for org 1. Does not get provisioned for other orgs.
logger=provisioning.plugins t=2023-07-25T11:33:27.36+0000 lvl=info msg="Updating app from configuration " type=grafana-synthetic-monitoring-app enabled=true
Above happens as many times as there are orgs marked for provisioning
i gave figured it out.
For datasources you would use orgId for plugin configurations you need to use org_id
:slightly_smiling_face:
