Multiple comma separated values
Hallo,
is it possible to show multiple comma separated values ?
i have a value: 27.10,36.14,1006.37
27.10 Temperature
36.14 Humiditiy
1006.37 Pressure
can i cut this value to show in a panel ?
What is your datasource?
Datasource is Influxdb
I don’t know of any string functions within Grafana (there may be some) but usually database datasources have lots of string functions to enable all sorts of processing. I am not familiar with Influxdb but you could start here perhaps:
https://v2.docs.influxdata.com/v2.0/reference/flux/stdlib/strings/split/
The Problem is, i can’t do anything on the database, i have only read permission,
that’s why i wont make it with Grafana
With MySQL (and other) databases you can use functions within select statements (readonly) like:
select LENGTH(my_table_column) from my_table
You are not making any changes to the data.
So I would assume you could do the same with influxdb. So if that is a correct assumption you should be able to use a combination of string functions such as split, substring etc. Do some online searching, I am sure you will find some examples.
OK Thanks you, i will search again
