Looks like “sraoss-sunburst-panel” was deleted from the repository and I cannot find any information about it. Is this a bug or a temporary issue or is it permanent?
Any information on the topic is appreciated.
Thank you!
Thank you!
Are there any permanent/temporary solutions for this rather unexpected surprise?
With a bit of help via Slack I found that this plugin was listed in Grafana plugins as pending
(it still is https://grafana.com/api/plugins/sraoss-sunburst-panel/versions/1.0) and that my problem started when the owners of the repo, removed it from github (https://github.com/sraoss/grafana-sunburst-panel).
Dear @petre2dor,
I just found https://github.com/anzai/grafana-sunburst-panel. Don’t know if this is a fork of the original one or a different implementation. Maybe this helps.
With kind regards,
Andreas.
did you check using off the shelf react components like:
https://www.npmjs.com/package/sunburst-chart <- i’m trying to find a way to integrate this one… withou succes for now)
or
https://www.npmjs.com/package/react-zoomable-sunburst
