I install promtail binary and it works.
The promtail is hosted on a different server from loki server.
I don’t think promtail has authentication built-in. So the idea is to use nginx basic auth.
The problem is I am unable to do so.
When I use the follow settings, journalctl -xe
returns (98: Address already in use)
server {
listen 9080;
location / {
auth_basic "Authorization required";
auth_basic_user_file /etc/nginx/conf.d/.htpasswd;
Please share how I can make it work. If this can’t be done by nginx, please share how you do it
Thanks!
shawnngtq:
Hi @shawnngtq ,
The error probably means that there is already some process listening on the port 9080 .
You can either find what it is or you can try to use a different port.
See this stackoverflow discussion about the similar question
BR
@findmyname , I know, it’s running promtail. I want nginx basic auth before loading the promtail page
b0b
February 13, 2023, 3:37pm
4
@shawnngtq , Promtail does support basic_auth
in the clients
seciton
Configuring Promtail Promtail is configured in a YAML file (usually referred to as config.yaml) which contains information on the Promtail server, where positions are stored, and how to scrape logs from files.
Printing Promtail Config At Runtime If...
This is my config
clients:
- url: ${LOKI_URL}
basic_auth:
username: ${LOKI_BASIC_AUTH_USER}
password: ${LOKI_BASIC_AUTH_PW}
external_labels:
cluster: ${K8S_CLUSTER}
@b0b , I want to hide the promtail behind nginx basic auth.
The same way we config for Loki. But I do not see such an option …
b0b
February 14, 2023, 8:10am
6
Ok, sorry, I misunderstood.
no worries
I feel that it can’t be done. Unless promtail add this basic auth so that it works exactly like prometheus’s node exporter.
Hoping someone here has done it
system
Closed
February 14, 2024, 3:03pm
8
