I run Grafana on my Rpi. I made a dashboard, where it shows my wheater station. Now I want it public, that I do not have to log in every time. How can I do that ?
I would say that “public” is a dangerous word to use here - I doubt that you
really do want to expose this interface to anyone and everyone.
What I believe you’re looking for is “anonymous authentication”. See
#anonymous-authentication for details.
Antony.
Thank you. It worked !
Is it possible to access the Dashborad even if I am not at home in my network?
Yes, provided you have a VPN connection or any other method for accessing a
computer in your home network. That is a question of remote network access,
though, and is nothing specific to Grafana.
Regards,
Antony.
Okay, their is no other way ?
Well, no, otherwise anyone on the Internet would be able to get at the
machines in your home network, and that is “generally regarded as
undesirable”.
You have a router connecting you to the Internet. It contains a firewall,
which blocks access from the outside to the inside. It does that for a good
reason.
Antony.
