Show total consumption by day
Hello. I am looking to create a very similar dashboard, but am having trouble doing so. I am taking data from welds I am getting and trying to find a daily average of these values and plot them over time. My data is coming from SQL and is in a table format. Can you help me create a similar plot? Or maybe share a link to yours to see if it will help me? Thanks.
I do not have a consistent number of welds per day / per second.
You can also define “Interval” variables, say $vlapse_days in the panel settings, with a predefined and customized ranges (eg. “30d, 60d, 90d”).
This way, you will use the $vlapse_days variable in the “Relative time” field and in the dashboard you can then change the period for this panel (and all panels that use this same variable).
