I would like to inquire if it is possible within Grafana to develop a single dashboard which can be utilized against one or more pieces of the same equipment.
The example I would share is if I had 10 wind turbines. If all turbines had the same properties and data points, can I build a single dashboard which I can choose a particular turbine from a list and it will display its metrics?
The list would be either a drop down list of all common pieces of equipment and the panels below would be populated with the predefined properties. Once the equipment is selected, the metrics would appear. If you were to select a new piece of equipment, it would then display its metrics.
Is this possible within Grafana?
Thank you,
Shaun
