SingleStat Title does not appear for single value
I have 2 datasources.One with Single Node and another is 3 Node setup.I am using Stat panel to display the total Memory at each Node.For 3 Node setup the 3 Node names are displayed automatically because of aliasing
But for Single Node Setup which returns only one value.The Node name is not displayed.
My Settings Page is
How can i show the Node value as title for single Node setup.
What version of Grafana are you using? Looks like you have not updated to Grafana 7.0 yet, so I would start there.
@dianapayton I am currently using Grafana v6.7.3.Does v7.0 solve this issue.
I’m not sure, but the panel editor was significantly changed and upgraded. I suggest upgrading and then trying it out.
