Hi all,
I have a starred dashboard that I set as “Home Dashboard” but when I login I always get the standard home page.
Configuration:
What I see after login:
Grafana version is 6.7.4.
Thanks for any hints,
Patrick
Hi all,
Configuration:
Patrick
Hm. I’m not able to reproduce this. Maybe a long shot, but have you tried clearing out the cookies?
That did not occur to me. I did clear the cache, of course.
Now cleared cache and cookies - no change.
I already had a dashboard named “FreeNAS” as my home dashboard, then later deleted that and renamed a reworked copy to “FreeNAS”, then set the new “FreeNAS” as my home dashboard.
Possibly something with the IDs and stuff?
OK, that can be tested, of course …
Renamed dashboard to “Test”, set as home, no change.
“Test”, Dashboard Settings, Save as … “FreeNAS” - star that, set that as home, same again.
Set a completely different dashboard as home - standard home page all over.
I confused the setting for the organisation and the preference for a particular user. Works as documented.
