Time Offset when using $__timeGroup
Grafana 7.5.15 on fedora 35
Display average by hour.
    SQL Query
    SELECT
    $__timeGroup(ts_mesure,1h) as time,
    avg(masse) as value
    FROM mesures
    WHERE
    $__timeFilter(ts_mesure) AND
    proprietaire = $proprietaire AND
    numero_ruche = $numero_ruche
    GROUP BY 1
    ORDER BY 1
  • What happened?
The time is UTC. When I use the series directly (without average and $__TimeGroup), display is right.
When I use the SQL Query above, data is displayed like UTC was localtime (-2h offset)
    Have the display like raw series (without) offset.
    See above query
    No
    How to put group by time series in the format as by Alias
welcome to the :grafana: forum, @pjuhen
there are many threads on here about using those time macros with a SQL data source, and managin UTC issues. I highly recommend you search through the forum for similar topics :+1:
and what data source are you using? mysql?
I use Mariadb.
This is a view of the panel :
Above, using all the measures with the request :
SELECT
ts_mesure AS “time”,
masse
FROM mesures
WHERE
numero_ruche = $numero_ruche AND
ORDER BY ts_mesure
Down, to obtain an average per hour :
SELECT
$__timeGroupAlias(ts_mesure,1h,0),
avg(masse) as poids
FROM mesures
WHERE
GROUP BY 1
ORDER BY 1
The two panels use the same data, with time in UTC.
Above, display is right.
Down, display is not converted from UTC to local.
Thanks,
Regards,
have you tried reproducing this error on Grafana 9? Grafana 7.5 is quite old and the time series panel has undergone a lot of development since then…
