In Our Gitlab yml we are using below image for k6 image:
** name: loadimpact/k6**
But we would like to add node dependency k6-to-junit in our project. Since the above image doesn’t contains Node what should be the best approach in pipeline inorder to use the above dependency.
Hi, sorry about the late response, and welcome to the forum
You could build an image using loadimpact/k6 as base (FROM loadimpact/k6) and install Node and k6-to-junit on top.
Or, since the k6 image only really bundles the k6 binary, you could build from a Node base image and have a COPY instruction to just copy the k6 binary: COPY --from=loadimpact/k6:latest /usr/bin/k6 /usr/bin/k6.
