403 Error in Metrics dropdown
    Grafana 9.5.2 Enterprise and Redhat UBI 9
    Grafana and Prometheus + Postgres_Exporter
    Build docker image and upload to GKE
  • What happened?
    In Grafana URL after adding Prometheus Database (test is success) and in Add Visualization after chosing Source and selecting Metric gives 403 error
    List the metrics that are available in Prometheus
    Error
<!doctype html>403403 Forbidden
