550rc from alert test with Sendgrid
8.1.5v via Helm chart
I’m trying to set up a notification channel
By setting Sendgrid as SMTP server. We’re using API key as a method of authentication
  • What happened?
Sendgrid returns 550 code: Unauthenticated users are not allowed. When using the same credentials via Powershell Send-MailMessage (copy-pasted from grafana.ini) it works great. I’ve tried the same with base64 encoded password, Sendgrid Azure account and different TLS settings
I’ve expected that Grafana will be able to use Sendgrid as an email notification channel
grafana.ini:
smtp:
enabled: true
host: smtp.sendgrid.net:587
from_address: grafana@notify
from_name: grafana
skip_verify: false
username: apikey
startTLS_policy: MandatoryStartTLS
password: xxxxxx
UI: Failed to send alert notifications
Logs: 550: Unauthenticated users are not allowed
Also smtp configuration, but cant link them as I’m a new user
