Hey k6 crew. I have a question about why my abortOnFail option is not working for me.
I have 2 scenarios which I think are references by the error rate threshold/check
'http_req_failed{scenario:browse_peak}': [{ threshold: 'rate < 1.0', abortOnFail: true, delayAbortEval: '30s' }],
'http_req_failed{scenario:browse_gate_rush}': [{ threshold: 'rate < 1.0', abortOnFail: true, delayAbortEval: '30s' }],
I have a test which throws a ton of requests timeouts on a purposely low bandwidth client connection to my test environment. the resulting output looks like this… why wouldn’t 9% http_req_failed not trigger the check to terminate the test?
█ guest
✗ status is 200
↳ 96% — ✓ 4300 / ✗ 176
█ browse
✗ status is 200
↳ 95% — ✓ 4281 / ✗ 198
█ options
✗ status is 200
↳ 96% — ✓ 4283 / ✗ 177
█ browse_guest
✗ status is 200
↳ 99% — ✓ 4137 / ✗ 14
checks................................: 96.78% ✓ 17001 ✗ 565
data_received.........................: 117 MB 184 kB/s
data_sent.............................: 18 MB 28 kB/s
dropped_iterations....................: 1229 1.937985/s
group_duration........................: avg=3.26s min=16.53ms med=443.48ms max=1m0s p(75)=1.45s p(99)=1m0s count=17566
http_req_blocked......................: avg=1.41s min=0s med=5µs max=29.98s p(75)=409.93ms p(99)=26.11s count=35461
http_req_connecting...................: avg=1.09s min=0s med=0s max=29.98s p(75)=409.86ms p(99)=26.11s count=35461
http_req_duration.....................: avg=2.53s min=0s med=395.91ms max=1m0s p(75)=1.37s p(99)=47.55s count=35461
{ expected_response:true }..........: avg=1.44s min=76.15ms med=418.65ms max=59.15s p(75)=1.31s p(99)=14.65s count=31965
✗ { test_type:browse_guest_peak }.....: avg=1.79s min=0s med=308.17ms max=1m0s p(75)=1.22s p(99)=30.48s count=12014
✗ { test_type:browse_peak }...........: avg=2.96s min=0s med=477.27ms max=1m0s p(75)=1.52s p(99)=1m0s count=7806
✗ { test_type:concepts_guest_peak }...: avg=2.83s min=0s med=370.08ms max=1m0s p(75)=1.32s p(99)=1m0s count=7824
✗ { test_type:concepts_peak }.........: avg=2.94s min=0s med=463.07ms max=1m0s p(75)=1.45s p(99)=1m0s count=7817
http_req_failed.......................: 9.85% ✓ 3496 ✗ 31965
http_req_receiving....................: avg=174.94ms min=0s med=73µs max=52.31s p(75)=244µs p(99)=3.87s count=35461
http_req_sending......................: avg=39.67µs min=0s med=29µs max=2.59ms p(75)=51µs p(99)=155µs count=35461
http_req_tls_handshaking..............: avg=0s min=0s med=0s max=0s p(75)=0s p(99)=0s count=35461
http_req_waiting......................: avg=2.36s min=0s med=388.1ms max=1m0s p(75)=1.21s p(99)=47.17s count=35461
http_reqs.............................: 35461 55.917717/s
iteration_duration....................: avg=12.48s min=13.09ms med=5.46s max=1m29s p(75)=17.4s p(99)=1m2s count=20392
iterations............................: 20392 32.155723/s
transaction_time......................: avg=2728.538544 min=0 med=404.536 max=60009.313 p(75)=1355.093 p(99)=60001.3871 count=17566
vus...................................: 1429 min=200 max=1429
vus_max...............................: 1429 min=200 max=1429
