Grafana version: 8.5.2
OS: Windows 10
Hi all,
I am trying to create a batch file (or other code) that will set up a connection from my InfluxDB to my Grafana.
The only way I found to implement that connection is by using the " Add a data source" on the Grafana UI.
Is it possible to add InfluxDB as a data source using CLI or some sort of configuration file (while not using the UI at all)?
Thanks in advance,
Or Shahar
