Adding dashboard to same Org succeeds, adding it to another Org fails
Hi Folks,
    -Grafana v8.1.1 (90c87a52f7)
    -Use API to add a dashboard to another Organisation
  • How are you trying to achieve it? What happened?
I managed to download the dashboard json with:
% curl -XGET http://admin:whatever@localhost:3000/api/dashboards/uid/qiAZX2kGa>standard_dashboard_20210823.json
And I managed to make a change to a panel and after bumping up the version number, the UPDATE was successful to the same Org.
However, when I change Orgs and try again, then this:
<change Org context here> ; curl -X POST -H "Content-Type: application/json" -d @standard_dashboard_20210823.json http://admin:whatever@localhost:3000/api/dashboards/db
{“message”:“Active organization changed”}
{“message”:“Dashboard not found”,“status”:“not-found”}
I tried with the API token added as described here:
No dice.
This behaviour is unchanged when the Org has this dashboard or when it does not have this dashboard.
    -Dashboard added with no error as it does when adding to the same Org from which the dashboard was downloaded :point_up:
    Dashboard HTTP API | Grafana documentation
Thanks guys for tips on how to pull out of this :pray:
Eric
[SOLVED] Dashboard id has to be null as advised here: Unable to create grafana dashboard through api but working through UI (import option) with same Json file - #4 by daniellee
