I have a data series and all the metadata is negative values (rssi from my LoraWAN node).
The fill is to zero, but I would like it to be below the line. I can only find fill below to the other series.
Input will be appreciated
@johans - I have the same concern, but I’m graphing wireless client signal strength. Were you able to resolve this?
I, too, have the same need but for Outside temperature (Celsius) being graphed against drive temperature. Ideally, I’d like the outside temp to be a background gradient going to the bottom of the graph rather than going to zero (in the Midwest where my line is from -23c to 25c - so far!).
Have there been any updates?
