What is the data source situation?
I query from an InfluxDB2. For (more or less) the same timestamp there are always two rows, one with tag “ch1”, the other with tag “ch2”.
What do I want to achieve?
I want to plot not the values of “ch1” and “ch2”, but the Difference of the two values.
First naive try and why it does not work as I want:
I make two queries like this:
from(bucket: "myBucket")
|> filter( some Filter )
|> filter(fn: (r) => r["channel"] == "ch1")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
of course the other filters for “channel” = “ch2”. Additionally I add in Grafana a Transformation “Binary operation” and choose “minus” and I activate “Replace all fields”. And this works!
Problem: The Graph which is plotted is very very “jiggery”. It does look very bad.
What do I want to have changed?
I would like to use the result of above and then aggregate the data such that e.g. I chop all data into 2-minute-pieces (or even 5-minute-pieces) and use for each of these intervals the MAXIMUM of the values. I hope I explained good enough.
However, I cannot google how this can be done. And ChatGPT is really really bad with Grafana…
A second solution which works, but is bad in another way:
instead of making two queries and a transformation I can do all this logic in the query itself. I will paste the query below. This query yields exactly what I am looking for. BUT: The evaluation of this query takes A LOT of time. On every refresh it takes like 10 seconds to give me data (if I restrict the data to a 24-hour-window, if I go for larger time span, it takes even way more…).
The query:
|> truncateTimeColumn(unit: 1s)
|> filter( some filters )
|> filter(fn: (r) => r["channel"] == "ch1" or r["channel"] == "ch2")
|> pivot(rowKey: ["_time"], columnKey: ["channel"], valueColumn: "_value")
|> map(fn: (r) => ({r with delta: r.ch1 - r.ch2}))
|> drop(columns: ["ch1", "ch2"])
|> aggregateWindow(every: 2m, fn: max, column: "delta")
My hope:
The two queries and the transformation from the first naive solution are very fast, so I was hoping there is a way that Grafana post-processes the data after the transformation to achieve similar results as the slow solution 2.
I did try to google that but I was not able to find something. I also tried ChatGPT but I was surprised how bad ChatGPT is when it comes to Grafana (in comparison to its coding skills)
